DCE 7.4.1 user access logs?
  • EcoStruxure IT forum
  • DCE 7.4.1 user access logs?
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 03:11 PM . Last Modified: ‎2024-04-08 01:03 AM
1159
Where can I get log of who and when did users log in to Datacenter expert?
(CID:116920701)
1158
Hi ieslmarketing,
This information can by easy find in DCE Web-console under Event Log tab in Category Security, for example https://you_DCE_server/desktop/#eventlog&category=Security&relativeTimeDays=7 (or http://you_DCE_server/desktop/#eventlog&category=Security&relativeTimeDays=7).
You must have rights administrator of DCE server.
With best regards.
(CID:116920708)
Replies 7
1159
Hi ieslmarketing,
With best regards.
(CID:116920708)
I logged out and logged back in but it shows blank still:
(CID:116920955)
Hi ieslmarketing,
I suspect, that events are displayed after a while, for example, 24 hours, and not immediately. This needs to be checked...
With best regards.
(CID:116920966)
Hi ieslmarketing,
Unfortunately, the user login/logout in the DCE Web-console is not journaled as events. Therefore, they are not displayed in what you are convinced.
But the user login/logout in the DCE-client is logged and can be seen in the Event Log tab.
At the same time, the DCE-server logs both events, all failed attempts to login to the DCE Web-console and the DCE-client. And also logged out due to error events.
With best regards.
(CID:116923309)
Posted: ‎2020-07-03 03:12 PM . Last Modified: ‎2024-04-08 01:03 AM
Is the Event Tab located to the bottom right of the CLient? I am going through the options menu and I am not seeing anything labeled event logs.
Do advise.
(CID:116923304)
ieslmarketing, Event Log tab in DCE Web-console, not in DCE-client:
With best regards.
(CID:116923306)
Posted: ‎2020-07-03 03:12 PM . Last Modified: ‎2023-10-22 01:10 AM
