Posted: 2020-07-03 06:13 AM . Last Modified: 2024-04-08 10:52 PM
is it possible to upgrade a 5 nodes free DCE server or does the customer have to make a new VM with the latest version ??.
(CID:108825817)
Posted: 2020-07-03 06:14 AM . Last Modified: 2024-04-08 10:52 PM
Hai Jesper,
i mean from 7.2.6 to 7.27 or higher, with the upgrade file.
The server stay's as a 5 nodes free version.
(CID:124523657)
Hi Frans de Groot
Yes, the customer can upgrade their demo DCE to a production server. They only need to purchase a activation key for the virtual appliance.
For further details see:
Upgrading a StruxureWare Data Center Expert virtual appliance demo version to production
Jesper
(CID:108825821)
As far as I am still aware of when using the free version you will need to make a backup and then install the newer free version (start from scratch) and then restore your data/config from the prior backup. The Upgrade file is only for the paid versions unless Schneider has changed it's policy since we first used DCE.
(CID:108825867)
Just an FYI, backups will only work with the same version. You can not create a backup of 7.2.6 and import into 7.2.7.
(CID:108825918)
Hai Jesper,
(CID:124523657)
Posted: 2020-07-03 06:14 AM . Last Modified: 2023-10-31 10:23 PM
