Customize DCE report with 3rd reporting tool
  • Customize DCE report with 3rd reporting tool
129
72
Posted: ‎2020-07-02 07:24 AM . Last Modified: ‎2024-04-10 01:41 AM
722
Hi Sir,
Could our DCE can do the customize reporting with 3rd reporting tool such as BIRT report ?
What is the DCE database and How do we connect the BIRT report to DCE database to query the raw data ?
BR,
Nathawat
(CID:87589216)
Posted: ‎2020-07-02 07:25 AM . Last Modified: ‎2024-04-10 01:41 AM
I Nathawat,
From DCE you can easily import reports into MS EXCEL and customize them to any fashion you want. These reports can be a easily derived from CSV export from DCE and opening the same into MS Excel.
(CID:87589218)
Hi Nathawat
In addition to Vineet's comments, you can also use BIRT  (StruxureWare Insight) to interrogate DCE's XML API.  The API is documented here.  You can become familiar with the way the API works using soapUI
Cheers
(CID:122688529)
Posted: ‎2020-07-02 07:25 AM . Last Modified: ‎2023-10-31 10:22 PM
