Posted: 2020-07-04 07:27 PM . Last Modified: 2024-04-04 11:13 PM
Hi team,
we would like to insert custom properties in customized reports, but we do not find the data source in the Insight Reports client.
Do you have any information about this issue?
Thanks in advance.
(CID:132657238)
Javier, what is the data source for the report(s) you are customizing? Are you using an ETL export database as the source or something else?
GregS
(CID:132657254)
Posted: 2020-07-04 07:27 PM . Last Modified: 2024-04-04 11:12 PM
Hi Greg,
we would like to import the data directly from the database, without ETL, using the editor included in the Insight license.
Regards
(CID:132657364)
Posted: 2020-07-04 07:28 PM . Last Modified: 2024-04-04 11:12 PM
Hi Greg Sterling,
do you have any idea about how we can do this?
Regards
(CID:132660294)
Hello Javier.
The internal DCO database schema is not something which is published. The best advice I can offer you would reach out to Lasse Simonsen (Lasse.Simonsen@schneider-electric.com) as you may be able to get assistance from the CSP team regarding options or a custom integration.
Regards
Greg Sterling
(CID:132661195)
Posted: 2020-07-04 07:28 PM . Last Modified: 2023-10-22 01:07 AM
