Posted: 2020-07-03 04:39 AM . Last Modified: 2024-04-08 11:36 PM
Is possible create in a same floor plane two Data Halls (DH) and each DH with two corridors ?
I created the DH and corridors to place cooling units (CRAC downflow), how DCO assume which corridors will supply (cooling) the specific DH ?
Fabio Carvalho
(CID:106891281)
HI Fabio!
You can use vertical grills to model your cooling configuration. You can configure incoming and outgoing airflow for each Data Hall.
(CID:106891484)
Hi Valentin WE have a DC where CRACs are in a corridor adjacent to the data hall. Can vertical grilles be used for both hot air return near the ceiling as well as under raised floor for supply? Thanks
(CID:106891495)
Posted: 2020-07-03 04:39 AM . Last Modified: 2024-04-08 11:35 PM
Yes, it can.
(CID:106891660)
How can I associate the vertical grill to the room, i put the vertical grille on the Data Hall, but how I can associate this to the technical corridor (CRACs room) ?
(CID:109447541)
Hi Fabio
I thibk the only way to limit CRAC cooling to a white space area is to have them both in a single room. All the white space load in a room is cooled by one or more CRACs in the room. A CRAC can only cooling in one room. I use walls to model corridors on a raised floor. So if you have 2 rooms with 2 corridors, you will need to model 2 rooms, each with a corridor (using a wall).
It sounds like you also want a single view of both rooms so I would use a "Floor Plan" (and optionally load a AutoCAD or similar single drawing showing both rooms and corridors) then model both rooms under the Location. This might do some of what you're after.
Example Navigation screen cap below
(CID:109447604)
Posted: 2020-07-03 04:39 AM . Last Modified: 2023-10-31 10:22 PM
