Connecting equipment to DCO using SNMP
  • Connecting equipment to DCO using SNMP
129
72
Posted: ‎2020-07-03 07:03 AM . Last Modified: ‎2024-04-08 04:19 AM
973
Hi everybody!
Could anybody know how can I connect my HP equipment to DCO using SNMP?
(CID:108828691)
  • Data Center Operation
973
Hi local,
Other than HP OneView, the possibilities I can think of is integration with ITO and/or DCE. ITO is primarily CPU utilization and power usage (derived from CPU utilization) but also temperature as far as recall.
Kind regards
(CID:108828893)
Replies 5
Hi local, Can you please add more information and details describing the system(s) you would need to integrate with DCO, thanks. Kind regards
(CID:108828697)
Hi Jef, We need to collect some information (server health, power & thermal usage) directly from DL580 servers using SNMP. I know that DCO allows to configure external systems like HP OneView, but OneView doesn't support Gen5 servers, that we have in our infrastructure.
(CID:108828702)
974
Hi local,
Kind regards
(CID:108828893)
Hi Jef, Thanks for reply! I've already read about ITO and now will try to deploy it. Best regards
(CID:108828894)
Posted: ‎2020-07-03 07:03 AM . Last Modified: ‎2023-10-20 05:10 AM
