Connecting devices with NO/NC dry contact to DCE AP9465 Server
  • Connecting devices with NO/NC dry contact to DCE AP9465 Server
129
72
Posted: ‎2020-07-03 09:34 AM . Last Modified: ‎2024-04-08 03:30 AM
1099
In one of our projects, client wants to connect below devices with NO/NC dry contacts to DCE AP9465 Server:
  1. Fuel Tank
  2. Generator 1
  3. Generator 2
  4. Main Gate DSM "Door status monitor"
I understand that we have modbus rs485 to tcp/ip converter (TSXETG100) but for the above can anyone suggest a device.. may be a third party device which was tested and working?
Thanks & Regards
Shemil
(CID:110012070)
Hi Shemil, you can also use the Netbotz 250 (NBRK0250) in combination with the dry contact cables, connected to the Universal sensor ports
Used for connecting APC sensors and third-party dry contact sensors. (See “Connect
sensors to universal sensor ports” on page 12 for a list of applicable APC sensors.) Thirdparty
dry contact sensors require a NetBotz Dry Contact Cable (NBES0304).
This Netbotz can be connected to you're generator via the dry contact cables and the netbotz itself can then be monitored via the DCE
(CID:110012130)
Hi Shemil,
You can easily use Schneider Automation Server for such requirements which can again hook back to SXW DCE. See my post here:
(CID:110012075)
(CID:110012130)
Posted: ‎2020-07-03 09:34 AM . Last Modified: ‎2023-10-20 05:10 AM
