Connecting a Generator to Data Center Expert V7.2.0
Showing results forΒ
Did you mean:Β
  • Connecting a Generator to Data Center Expert V7.2.0
129
72
Posted: β€Ž2020-07-04 02:09 AM . Last Modified: β€Ž2024-04-05 03:55 AM
7135
Dear Support,
We are trying to connect 2 generators of type FG Wilson Easygen 2200 to the Data Center Expert software using a Modbus to TCP gateway TSXETG100. Unfortunately we are not managing to get any Modbus communication between the Generators and the TSXETG100 gateway.
Kindly find attached a photo of the TSXETG100 gateway showing the orange LED of the RS485 port. Is this correct or should it light green?
Also please note that we are using CAT6A cable and not Belden 9841 as recommended in the attached TSXETG100 Installation Guide.
Could it be that we are using the wrong cable?
Thanks as always in advance for your feedback on the matter and would appreciate any experiences that you may have had in this regard.
Regards
Matthew Farrugia
Schneider Electric TSXETG100 Installation guide.pdf
(CID:126179372)
Replies 50
  • « Previous
    • 1
    • 2
  • Next »
Posted: β€Ž2020-07-04 02:15 AM
  • « Previous
    • 1
    • 2
  • Next »
