Configuring RP-C through USB
  • EcoStruxure IT forum
  • Configuring RP-C through USB
124
110
65
Back to EcoStruxure IT forum
AQ
Lieutenant JG AQ
Lieutenant JG
Posted: ‎2021-03-02 07:14 AM . Last Modified: ‎2021-03-02 07:15 AM
2953
Good day,
Is there any way of configuring RP-C solely through USB connection? I wish not to rely on BACNet device discovery, as I am not sure if this won't cause any IP conflicts. Instead, I would like to set RP-C IP address through USB connection and then grant it access to factory's network. Can this be done anyhow? If USB won't work, can I connect through Ethernet port, send some packets (eg. through WireShark) and configure RP-C without BACNet discovery?
With regards
  • Building Operations
  • RP-C
  • usb
JLehr
Sisko JLehr Sisko
Sisko
Posted: ‎2021-03-03 12:00 PM . Last Modified: ‎2022-10-19 01:51 AM
2932
Hi Jerzy,
You'll have better luck posting your question in the Building Operation forum.
https://community.se.com/t5/EcoStruxure-Building-Operation/bd-p/ecostruxure-building-forum
Best,
Jackie
JLehr
Sisko JLehr Sisko
Sisko
2933
Hi Jerzy,
Best,
Jackie
AQ
Lieutenant JG AQ
Lieutenant JG
Posted: ‎2021-03-03 11:40 PM
In response to JLehr
2925
Thank you. I wlll try my luck there then.
Regards
PhuocLe
Crewman PhuocLe
Crewman
Posted: ‎2022-12-16 01:18 AM
In response to AQ
Hi @AQ , I am having the same problem, did you find the solution to solve this problem?
This is a heading
