Cold aisle containment
  • Cold aisle containment
129
72
Posted: ‎2020-07-05 08:23 PM . Last Modified: ‎2024-04-03 01:14 AM
997
I have one side containment that has only one row and connected to the room wall when I try to adjust this in ITA but the result of the heat map and air flow calculate have distorted value.
Is there an example to do this?
(CID:146277887)
  • Data Center Operation
Hello Tanawat
I do not believe a one-sided cold or hot aisle containment system is currently supported in DCO or ITA so the cooling calculations may not properly handle the configuration. I'm hoping someone from dev will confirm.
Regards
Greg Sterling
(CID:146669907)
Hi Tanawat,
As Greg mentioned that would be unsupported configuration, currently in DCO it is expected that Hot/Cold Containment System should be equipped with actual equipment (such as racks, cooling units and other floor mounted equipment).
Kind regards
(CID:146670079)
Posted: ‎2020-07-05 08:23 PM . Last Modified: ‎2023-10-20 05:09 AM
