Posted: 2020-07-05 06:55 PM . Last Modified: 2024-04-03 02:49 AM
I found the update description from documentation for DCO 8.3 as follows:
"Energy Cost license removed and energy cost is now under ops license"
What does this mean? Is the Energy Cost Report removed?
When I tried to setup DCO 8.3 and restored a solution with only Operation and Energy Cost license, I could not found Energy Cost Report under Report tab.
It is the correct outcome of the update?
BR,
TJ
(CID:143264058)
Posted: 2020-07-05 06:56 PM . Last Modified: 2024-04-03 02:49 AM
The EnergyCost feature should be included with the base Operations or Colo licensing with DCO 8.3
From your reports menu, try clicking the pull-down menu highlighted below and choosing restore default designs.
I suspect you'll see the energy cost report appear in your view at that time.
Regards
Greg Sterling
(CID:143264629)
Regards
Greg Sterling
(CID:143264629)
Hi Greg,
It works! Thanks a lot
BR
TJ
(CID:143264836)
Posted: 2020-07-05 06:56 PM . Last Modified: 2023-10-20 05:08 AM
