Posted: β2020-07-03 04:30 AM . Last Modified: β2024-04-08 11:38 PM
HI
i have DCE AP9470.if i want draw chart in DCE can i do that. and how do i ?
for exampel : if i want draw ups and other electrical devices in DCE How do i that ?
thanks
(CID:106210707)
Hi Hojjat Saeidi,
You can add the drawing by using these format (bmp, gif, Jpg, png, jpeg) in map view, see the attached picture and follow the steps.
1) Go to map view ==> 2) Edit map ==> 3) Map setting ==> 4) Select Image ==> 5) Save ==> 6) Drag and drop the devices as per its location.
Rana Ajmal
(CID:106210714)
Hi Hojjat Saeidi,
Rana Ajmal
(CID:106210714)
Hi Hojjat
Simply No π
BR
John
(CID:106210773)
Posted: β2020-07-03 04:30 AM . Last Modified: β2023-10-31 10:20 PM
