Cannot upgrade DCE from 7.7.0 to 7.8.0
Showing results forΒ
Did you mean:Β
  • Cannot upgrade DCE from 7.7.0 to 7.8.0
129
72
Posted: β€Ž2020-07-05 11:51 PM . Last Modified: β€Ž2024-04-02 11:46 PM
1714
When trying to apply server upgrade, I select the lst file associated to the 7.8.0 upgrade, however, I do not have an option to apply the upgrade.
What do I do to upgrade the system?
(CID:152079605)
Posted: β€Ž2020-07-05 11:52 PM . Last Modified: β€Ž2024-04-02 11:46 PM
1714
Hi Robert,
I think your upgrade path might be incorrect - I think the correct upgrade path would be 7.7.0 -> 7.7.1 -> 7.8.0.
DCE 7.8.0 download page says "A software update is available from DCE 7.7.1. For earlier versions please contact Tech Support.".
Kind regards
(CID:152079764)
Replies 9
Dear Robert Maday,
Can you show a couple of screenshots of your problem? And then they will help you better and faster πŸ˜€.
With respect.
(CID:152079616)
From the apply server update, I choose Import,
Select the proper LST file as below.
Then it bounces back to the original one without any information from the pkg that I selected.
(CID:152080467)
Checked upgrade zip-file checksum? Is she correct?
(CID:152080471)
Dear Robert Maday,
I suspect, that this may be a known problem, which is described in topics Update ISX Central 6.3.0 -> 7.0.0: nothing to update? and .
That is, you may need to clean install DCE-7.7.0 server and deploy your full backup to it. Only after that will it be possible to upgrade to DCE-7.8.0.
Hope this helps you.
With respect.
(CID:152079772)
1715
Hi Robert,
Kind regards
(CID:152079764)
7.71 - Installing now - Had to contact Tech Support and prove valid software support.
Robert
(CID:152080787)
Many thanks for the update, Robert
Kind regards
(CID:152080904)
Confirmed the .zip file checksum is valid.
(CID:152080473)
Posted: β€Ž2020-07-05 11:52 PM . Last Modified: β€Ž2023-10-20 05:07 AM
