Can we use Vizor without Capacity
Showing results forย
Did you mean:ย
  • EcoStruxure IT forum
  • Can we use Vizor without Capacity
126
65
Back to EcoStruxure IT forum
Posted: โ€Ž2020-07-03 02:01 AM . Last Modified: โ€Ž2024-04-09 12:25 AM
968
All, can we use the Vizor app without having a Capacity license, customer just needs the asset part of Vizor ?
(CID:105471258)
  • Data Center Operation
968
Hi Jef, I managed to setup a test environment myself, with just the Operation license you are able to use the asset part of Vizor, so no more testing needs to be done. Sorry for asking ๐Ÿ™‚
(CID:105471395)
Replies 4
Hi Cees, I will try to test this and get back to you as soon as possible, thanks. Kind regards
(CID:105471380)
969
(CID:105471395)
Posted: โ€Ž2020-07-03 02:02 AM . Last Modified: โ€Ž2024-04-09 12:25 AM
Hi Cees, No problem at all & many thanks for sharing your test results, thanks. Kind regards
(CID:105471397)
Posted: โ€Ž2020-07-03 02:02 AM . Last Modified: โ€Ž2023-10-31 10:19 PM
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
