Posted: 2020-07-04 04:15 PM . Last Modified: 2024-04-05 12:17 AM
Hi Team ,
Our DCE monitor some third-party device like RackCDU , their water temp almost over 50 degree, I saw our DCE only can set to max 50 , can we make a change for this threshold maybe
80 degree ? There are still some sensor under high temp environment like transformer etc..
Your comment would be appreciated.
Best Regards
(CID:130092638)
Billy,
How about using 'Other Numeric" instead of "Temperature"?
Select Other Numeric, then maximum threshold.
You should be able to set the maximum value to 80.
p.s you might want to mask of the ip address, team viewer details or other stuff.Or simply set to internal... 😀
(CID:130092650)
Billy,
(CID:130092650)
Posted: 2020-07-04 04:15 PM . Last Modified: 2023-10-20 05:06 AM
