Can't create an ETL connection?
Showing results forΒ
Did you mean:Β
  • Can't create an ETL connection?
129
72
Posted: β€Ž2020-07-03 03:01 AM . Last Modified: β€Ž2024-04-09 12:06 AM
956
Hi , I 'm trying to create a simple ETL export database but somehow each time I try I get this error.. Any ideas where I might be going wrong?
(CID:106204760)
  • Data Center Operation
Replies 7
Hi Vineet, would you be able to reboot DCO server? Looks like a service isn't running.
(CID:106205128)
Hi Vineet, please post a screen shot of the previous page, showing the values in the fields to create the DB. Confirming you are trying to create and ETL Export DB on the DCO server and you're using "Manage internal databases" Cheers
(CID:106204871)
Posted: β€Ž2020-07-03 03:01 AM . Last Modified: β€Ž2024-04-09 12:05 AM
I agree with Ed, please post a screenshot of the previous page with filled-in parameters. Thanks
(CID:106204906)
Hi Vineet K. Sarin, did you solve your issue? Best, Stine
(CID:106206279)
956
I think I got the exact issue...the issues was with the uploaded database that I used from a client side. If I do a fresh install it works fine...
(CID:106206598)
Posted: β€Ž2020-07-03 03:02 AM . Last Modified: β€Ž2024-04-09 12:05 AM
Glad to hear it's working! Thanks for sharing πŸ™‚
(CID:106206600)
Posted: β€Ž2020-07-03 03:02 AM . Last Modified: β€Ž2023-10-31 10:19 PM
