Can't connect to https://localhost:8080
  • Can't connect to https://localhost:8080
126
65
Posted: ‎2020-07-05 01:09 PM . Last Modified: ‎2024-04-04 12:38 AM
5552
Hi!
I've just installed Struxureware Portal and can't connect to https://localhost:8080 nor https://ServerIP:8080
It brings ERR_CONNECTION_REFUSED error.
Can't be the firewall.
The Portal version is 1.3.7
I have DCO 8.2.7 and DCE 7.6 installed.
(CID:134686696)
  • Portal
Posted: ‎2020-07-05 01:09 PM . Last Modified: ‎2024-04-04 12:37 AM
5544
Dear Javier Alejandro Pignata,
As far as I know, the latest version of the SxW Portal after the initial installation is available only via HTTP, i.e. you must use http://localhost:8080 (not HTTPS, see Installing and configuring the StruxureWare Portal).
If, for security reasons, you only need to use the HTTPS protocol, then the Jef Faridi answer may be helpful from topic :
By default, https is on port 8443.
If you need to disable http, then edit the "server.xml" file and un-comment (use "") the connection via HTTP / port 8080.
And for the https configuration, see the following guide:
http://liferaysatish.blogspot.se/2012/06/ssl-with-liferay-tomcathttp-to-https-on.html
I hope this is what you need.
With respect.
(CID:134686735)
Replies 7
5545
With respect.
(CID:134686735)
Thank you very much for your answer!
When i put the http://localhost:8080, It brings ERR_CONNECTION_REFUSED error and I don't know what it can be.
(CID:134688242)
It is not easy in this case to give any recommendations: try to completely uninstall the broken SxW Portal and reinstall it.
Please tell us which OS do you install SxW Portal on?
With respect.
(CID:134688246)
Posted: ‎2020-07-05 01:10 PM . Last Modified: ‎2024-04-04 12:37 AM
I tried. Still down.
My OS is Windows 10 Pro x64.
Thanks!
(CID:134690215)
Please, tell us if you could solve this problem or not?
With respect.
(CID:137103388)
I solved it. Thank you!
(CID:137104834)
Posted: ‎2020-07-05 01:10 PM . Last Modified: ‎2023-10-20 05:06 AM
