Can not login DCO desktop client in 8.2.2 version
  • EcoStruxure IT forum
  • Can not login DCO desktop client in 8.2.2 version
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 05:46 PM . Last Modified: ‎2024-04-04 11:48 PM
827
Hi Team ,
Our customer facing the issue about the topic ,they can login web client as well but can not login
to desktop client , I tried to change to 443 port and the issue still the same .
Also tried to changed the password , still the same .
I tried to download the client log but can not found the log file in customer's laptop ,
The network connection ports are all open by their MIS.
Can someone advice on what the problem  ? Many thanks.
Best Regards
(CID:131961709)
  • Data Center Operation
Replies 4
Hi Chu Li,
What is the notification message during the login session?
There should also be a ".log" file (in C:\Users\\.isxo\8.x\Operations\.metadata folder), that might contain some info.
Kind regards
(CID:131961976)
827
Dear Chu Li,
Is the DCO server running inside the VM player (e.g. Hyper-V) under another Windows OS host? If yes, I would advise you to enable ICMPv4 in the host Windows's firewall. Hope this helps.
Winnie
(CID:131962511)
Posted: ‎2020-07-04 05:47 PM . Last Modified: ‎2024-04-04 11:48 PM
Hi Winnie ,
Thank you kindly reply ,we are using VMWare esxi6.0 to run DCO and not sure if this issue relate to customer's network environment .
Best Regards
(CID:131965872)
Posted: ‎2020-07-04 05:47 PM . Last Modified: ‎2023-10-20 05:06 AM
