Posted: 2020-07-06 12:42 AM . Last Modified: 2024-04-02 11:28 PM
Hi
I am trying to update as below.
Our version is Server Build: 7.7.0.148
The upgrade version upgrade-7.8.0.47
When I try an upgrade it wont import the nbcpkg.lst file.
Can it go from our current version to the new version or does it require the version in-between first? I believe there was a version 7.7.1
thanks
Bruce
(CID:153551940)
The answer to the above is yes you do.
(CID:153551952)
Dear Bruce Phillips,
You are right: as follows from User assistance for StruxureWare Data Center Expert 7.x:
If you have more questions, please ask.
With respect.
(CID:153552099)
Hi Bruce Phillips,
The update to DCE 7.8.0 requires that your DCE is at 7.7.1.
The update path and instructions are always in the release notes for each version. You can see the release notes for the most recent version in the DCE documentation or in the PDF Library here in the help center, or on a DCE product page on apc.com.
Best,
Jackie
(CID:153552516)
Posted: 2020-07-06 12:42 AM . Last Modified: 2023-10-20 05:05 AM
