Posted: β2020-07-05 03:40 PM . Last Modified: β2024-04-03 11:21 PM
(CID:137727540)
Dear mark li,
To do this, there is a special resource Device Support, like in my screenshot:
Try it and you will succeed π.
With respect.
(CID:137727551)
Dear mark li,
With respect.
(CID:137727551)
Hi. I have WIB8000 with FW version 1.53. All, what I can see in DCE - item itself, without any sensors - nothing. In this chat I sow screen with remark about FW up when 2.0 for WIB8000. Where I can find it? May be in this case I'll see sensors STULZ throw WIB8000?
(CID:137727558)
Dear Ponomarev Vladimir,
Indeed, a lot of people say, that the Modbus DDF-file for Stulz WIB8000 does not work βΉοΈ. For example, see a very detailed topic about this.
The WIB8000 controller works equally well with the TCP/IP Modbus protocol as well as with the SNMP protocol. Therefore, I highly recommend you to use SNMP DDF-file for WIB8000, which is guaranteed to work. This SNMP DDF-file is not easy to find on the Device Support resource π, but my answer DDF support will help you.
I hope this is what you need.
With respect.
(CID:137727589)
Posted: β2020-07-05 03:41 PM . Last Modified: β2024-04-03 11:21 PM
Thanks for answer.
Yes, I knew about differences betwin Modbus&SNMP. It's not so difficult to find it. For this case was used DDF 23 version exactly for SNMP, but it not help.
(CID:137727596)
In this case, I suspect that the problem is not in the firmware of your WIB8000, but in its incorrect settings.
In any case, you'd better contact the vendor WIB8000 on this issue. There you can get new firmware and the correct settings.
With respect.
(CID:137727600)
Thank you.
I told about this picture
With this credentials peoples see the sensors of the WIB8000 in DCE (I mean 2.0 ver.). I just want to try. When I recive update from my friends, I'll try it and let you know about result.
(CID:137727610)
Ok, I would be interested to know the result.
(CID:137727633)
See Andrew Stoakes helpful hint for setting up the WIB8000:
Be aware that by default the port on the WIB is set to 162 not 161. By default DCE will scan on port 161, the WIB will need to be changed.
Hope this helps you.
With respect.
(CID:137727915)
Posted: β2020-07-05 03:41 PM . Last Modified: β2023-10-20 05:05 AM
