Can StruxureWare DCE, DCO and Portal be deployed in Cisco UCS Server ?
  • Can StruxureWare DCE, DCO and Portal be deployed in Cisco UCS Server ?
129
112
72
Posted: ‎2020-07-03 02:00 AM . Last Modified: ‎2024-04-09 12:25 AM
871
Dear Team,
We just got a confirmation from a Client is Bahrain that they have arranged a Cisco UCS Server for StruxureWare DCE, DCO and Portal deployment with Vmware Set Up with the attached specification.
Can the DCE, DCO and Portal be deployed in the below Server Specs.xlsx :
Line Number Part Number Description
2.0 UCSC-C220-M4S UCS C220 M4 SFF w/o CPU, mem, HD, PCIe, PSU, rail kit
2.0.1 CON-SNT-C220M4S SNTC-8X5XNBD UCS C220 M4 SFF w/o CPU, mem, HD
2.1 UCS-CPU-E52630D 2.40 GHz E5-2630 v3/85W 8C/20MB Cache/DDR4 1866MHz
2.2 UCS-MR-1X322RU-A 32GB DDR4-2133-MHz RDIMM/PC4-17000/dual rank/x4/1.2v
2.3 A03-D300GA2 300GB 6Gb SAS 10K RPM SFF HDD/hot plug/drive sled mounted
2.4 UCS-HD12TB10K12G 1.2 TB 12G SAS 10K RPM SFF HDD
2.5 UCSC-PCIE-IRJ45 Intel i350 Quad Port 1Gb Adapter
2.6 UCSC-CMAF-M4 Reversible CMA for C220 M4 friction & ball bearing rail kits
2.7 UCSC-RAILB-M4 Ball Bearing Rail Kit for C220 M4 and C240 M4 rack servers
2.8 UCSC-PSU1-770W 770W AC Hot-Plug Power Supply for 1U C-Series Rack Server
2.9 CAB-9K10A-UK Power Cord, 250VAC 10A BS1363 Plug (13 A fuse), UK
2.1 N20-BBLKD UCS 2.5 inch HDD blanking panel
2.11 UCSC-HS-C220M4 Heat sink for UCS C220 M4 rack servers
2.12 UCSC-MLOM-BLK MLOM Blanking Panel
2.13 VMW-VSP-STD-3A VMware vSphere 6 Standard (1 CPU), 3-yr, Support Required
2.13.0.1 CON-ISV1-VSXSTD3A VSphere Standard for 1 CPU; ANNUAL List 3-YR Reqd
2.14 UCSC-MRAID12G Cisco 12G SAS Modular Raid Controller
2.15 C1UCS-OPT-OUT Cisco ONE Data Center Compute Opt Out Option
(CID:105471106)
  • Data Center Operation
  • Portal
871
Hi Dhiman
It should be possible to run the DCO and DCE on VMware, as long as the minimum requirements are met for each software.
Only concern is that DCO and DCE will share the cores and memory of the one server you listed, so if i.e DCE are using a lot of resources to scan a lot of devices the DCO server might be affected.
Hope that helps
Jesper Thomsen
(CID:105471114)
872
Hi Dhiman
Hope that helps
Jesper Thomsen
(CID:105471114)
Dear Jesper, Thanks a lot for the prompt response. I will make sure that the Client is aware of the utilization of the CPU with regards to the three applications. As of now there will not be too much of traffic in the DC Expert as the solution is for only 50 Racks with 10 Rack PDUs and 2 UPS. Total nodes will be around 20. Thanking you once again and wishing you a great day ! Regards, Dhiman Das
(CID:105471120)
Posted: ‎2020-07-03 02:00 AM . Last Modified: ‎2023-10-31 10:19 PM
