Can AD authentication be used for DCO 8.1 Webmin and text login?
  • Can AD authentication be used for DCO 8.1 Webmin and text login?
129
72
Posted: ‎2020-07-03 10:04 PM . Last Modified: ‎2024-04-07 11:13 PM
787
AD authentication is supported for Web and desktop client in V8.1. Just want to know whether the Webmin and the "TEXT login" can also be configured to use AD?
(CID:123350060)
  • Data Center Operation
Hi Jimmy Leung,
This question is best asked directly by webmin developers.
If you have a certain level of knowledge and skills in systemd-based RHEL/CentOS-7.x, then you can perform the simplest integration OS Linux of your DCO-appliance (based on CentOS-7.3) to Microsoft Active Directory (as at ssh text-login, and at the level of webmin GUI-login).
The Internet has some detailed information on the type of "How to add a Linux system to Microsoft Active Directory"  (not to be confused with Active Directory Infrastructure with Samba4 - this is not the same as Microsoft Active Directory).
I am glad to answer your questions.
(CID:123350067)
Hi Jimmy Leung,
(CID:123350067)
Posted: ‎2020-07-03 10:04 PM . Last Modified: ‎2023-10-20 05:04 AM
