CSR Generation for Netbotz v4.x
  • CSR Generation for Netbotz v4.x
129
72
orlandogarcia
orlandogarcia Schneider Alumni (Retired)
Posted: ‎2021-08-04 07:14 AM
1683
Hello Team,
I am working with a customer that is looking for information on CSR Generation.
I've found 3 or 4 different posts here but the link to the process is broken in all of them.
Does someone have an updated link?
  • NetBotz
sesa298777
Crewman sesa298777 Crewman
Crewman
Posted: ‎2021-09-09 07:32 AM
Please take a look at FA366122
Kindest Regards, Rich...
Posted: ‎2021-09-10 01:32 AM . Last Modified: ‎2021-09-11 01:43 AM
If Data Center Expert uses a self-signed certificate, uncheck the Verify DCE Certificate in Trust Store option in the Settings > System > DCE Surveillance option.
MyGiftCardSite.com
Shaun
Commander Shaun Commander
Commander
Posted: ‎2021-09-10 02:37 AM
v4 bots have no facility for generating CSRs.  The certificates should be generated externally before being copied to the bot.
Usually you'll have two files, a private key and a public key/certificate.  If you open them in a text editor you should see one begins with "BEGIN RSA PRIVATE KEY" and one begins with "BEGIN CERTIFICATE".  You may also receive a "certificate chain" where both of these appear in the same file.
I'd recommend temporarily enabling HTTP if you're uncomfortable with the process, so ensure you have a Plan B if required.
If you have separate key & certificate, paste them both into the import dialogue in Advanced View (in Configuration->SSL).  If you have them both in a combined chain, they're already together so you can paste the whole thing.  You should end up with something like:
Then hit OK, and reboot the appliance (Tools -> Reboot Appliance).
