Posted: 2020-07-02 09:56 AM . Last Modified: 2024-04-10 01:04 AM
Can DCO output the layout as CAD(.dwg)? or to develop in the further version?
Thanks!
(CID:93913470)
Hi Branda,
It is possible to export the floor layout as dwg file.
Please see screenshot below
This function is available n DCO 7.4
Jesper
(CID:93913472)
Hi Branda,
Jesper
(CID:93913472)
Hi Jesper,
Just found this post and your answer and would like to ask another question in relation to that same subject.
After exporting a floor layout as a .dwg file extension (DCO 7.4.0) I tried importing it into Visio 2013 and Visio 2007 but both are reporting the following error message:
Is there something I am missing?
Is the version of CAD export we are using compatible with Visio import functionality?
(CID:94602548)
Posted: 2020-07-02 09:56 AM . Last Modified: 2024-04-10 01:03 AM
Hi Lukasz,
Can not really speak to why it is not possible to open the file in Visio since this is related to Visio functionality. The CAD export is designed to export files that can be open in AutoCad or similar products.
If you want to test the CAD export I would recommend that you try it in for instance DWG Trueview which is a free tool.
If you are still unable to open the file in for instance Trueview please get back to us so we can investigate this further.
Jesper
(CID:94602563)
Posted: 2020-07-02 09:56 AM . Last Modified: 2023-10-31 10:17 PM
