CA Integration
  • CA Integration
127
65
Posted: ‎2020-07-02 11:51 PM . Last Modified: ‎2024-04-09 01:05 AM
722
CA Integration
It Is possible to integrate DCE/DCO with CA DCIM ? If yes, how ?
Rgds,
(CID:105465825)
  • Data Center Operation
Replies 4
Hi Fabio,
If you are looking to get traps from DCE into CA Unicenter, the NMS integration feature can be configured to send traps to that system. You can also create SNMPtrap or V3 inform alarm actions to send to that system as well. There is no specific plugin or integration between the systems. CA can also not poll DCE via SNMP to gather any data on any of it's nodes.
Steve
(CID:105465828)
Hi Fabio,
How are you specifically looking to integrate the two?  The only other integration I see would be to have DCE poll the EcoMeter probe/gateway via snmp and the CA mib to monitor its devices in DCE.  It would be a good way to get  BACnet and RF code devices into DCE.
However if you are trying to monitor DCE devices with EcoMeter, then you would have to go to the devices directly.
(CID:105465904)
Hi Fabio Jose de Carvalho, did you see the suggestions and questions below? Best, Stine
(CID:105466080)
Posted: ‎2020-07-02 11:51 PM . Last Modified: ‎2023-10-31 10:17 PM
