Building Control Rooms
  • Building Control Rooms
129
72
Posted: ‎2020-07-02 11:59 AM . Last Modified: ‎2024-04-10 12:01 AM
1565
We have added some control rooms into the software which are an important part of our campus.  In these rooms I want to add tables, PC`s, monitors and power to represent what we actually see in the room.  There are a few problems
  1. When you add a table into the room you cannot place a PC or a monitor on the table.  It has to remain on the floor
  2. Cannot add PDU`s to tables
Are there any ways that this can be resolved?
(CID:96043622)
  • DCIM Support
Replies 11
1565
Hi Paolo,
Presently we do not support such placements. You can of course depict them using objects under 'Room Fixture' category as much as possible. PDUs are necessarily Floor mounted(or Rack mounted) hence, placing them on other objects is not possible.
(CID:96043627)
Hi
Do you foreseen to start supporting it in the near future for example similar to hotelling in itracs?
This will be an important part of our inventory
(CID:96043699)
Hi Paolo. supporting such objects are at present not in our road map. However, your requests can be reviewed by the developers, when you post your requirements under 'Feature Requests' section of EcoStruxure IT Help Center: http://sxwhelpcenter.ecostruxureit.com/display/public/Feature+requests?queryString=feature%20request
(CID:96043701)
Hi Aniruddha, I have filled out the features request, however, we I submit the form it does not confirm whether the request has been sent, it just goes back to the same page? Should there be some sort of confirmation?
(CID:96043865)
Hi Paolo, Your feature request has been received and will be processed shortly. You will get confirmation once the feature request is processed. /Søren
(CID:96043868)
Hi Søren, great thank you for the confirmation, however, in that case you may of received quite a few requests as I may of submitted it a few times 🙂 Paolo
(CID:96043883)
I have got a couple yes 🙂 You should have received an email with confirmation. /Søren
(CID:96043889)
Got the confirmation email, thanks
(CID:96043893)
Posted: ‎2020-07-02 12:00 PM . Last Modified: ‎2024-04-10 12:01 AM
Hi there, is there been any movement on this hotelling feature, I have not had any feedback
(CID:106205310)
(CID:110793210)
Posted: ‎2020-07-02 12:00 PM . Last Modified: ‎2023-10-31 10:17 PM
