BACNET over IP Simens controller accessible DDF for UPS
  • BACNET over IP Simens controller accessible DDF for UPS
129
72
Posted: ‎2020-07-05 12:11 AM . Last Modified: ‎2024-04-04 12:58 AM
896
HI,
We need a solution to integrate UPS with DCE. UPS is connected to BMS via Simens controller as gateway Bacnet over IP protocol. How can i access this Bacnet IP on DCE?
(CID:134036860)
  • DDF
Hi Shaik,
DCE can't communicate using Bacnet. I believe there are gateways out there that can translate...do Bacnet to Modbus. If you can do that, we can monitor via Modbus.
Steve
(CID:134036873)
Hi Shaik,
Steve
(CID:134036873)
Posted: ‎2020-07-05 12:12 AM . Last Modified: ‎2023-10-20 05:02 AM
