Autocad Import into Lab
  • Autocad Import into Lab
129
72
Posted: ‎2020-07-02 01:31 PM . Last Modified: ‎2024-04-09 04:31 AM
559
Can I import an Auto drawing into DataCenter Operations: Lab? If so, how?
(CID:97486419)
  • Data Center Operation
Tomestis,
I just tested this within DCO 7.5 Labs and could not find a way as the option for background settings is not there within the room environment.  Labs is usually used to simulate changes within a Data Center.
You will need to create the room within your base DCO server and import the drawing within there.  You can then open labs and select the room that you just imported the CAD drawing for.
Best Regards,
Cory
(CID:97486423)
Posted: ‎2020-07-02 01:32 PM . Last Modified: ‎2023-10-31 10:16 PM
