Posted: โ2020-07-02 09:23 AM . Last Modified: โ2024-04-10 01:14 AM
On alarm e-mails the text is (correctly) showing temperature information in Celsius, while the attached graph is showing the temperature in Fahrenheit.
Is there any way to change the unit of measure on the graph image?
Data Center Expert 7.2
(CID:93192933)
Hi Christian,
This is a known issue. There is a future fix in the system to rectify this. I have no timeline of when this will be implemented. If you have details of the customer who reported this issue, I will add it to the system for you. You can email me directly with this information (case number, customer name, email, phone number etc) and I will add it.
Breda
(CID:93192940)
This has been addressed in DCE 7.3 (available now). The graph will be created based on the Locale set on the server. This can be changed in the System -> Server Administration Settings -> Time Settings.
If for example you select English (Metric), then the graph will be created with English text and Celsius for units on a temperature sensor.
-Scott
(CID:105458761)
Hi Christian,
Breda
(CID:93192940)
(CID:93193039)
(CID:93193057)
We too are experiencing the same issue & have been experiencing this for some time. If we ever have to use the ISXC produced graphs as examples to our clients, a graph in fahrenheit when Australia has been using Celsius for decades, is not very professional.
Do we have a time frame on a fix?
(CID:100340071)
I received an email saying "Stine Verdelin Hansen, Community Manager commented on your answer" so where is the comment?
(CID:100340197)
Hi @Jeff.harrold , sorry for the late response. And for the confusion. What happened was I changed your answer to a comment, which led to a notification. Meanwhile, I am looking for someone to answer this.
(CID:101027861)
-Scott
(CID:105458761)
Posted: โ2020-07-02 09:24 AM . Last Modified: โ2024-04-10 01:14 AM
Awesome! Very good news ๐
(CID:105458764)
I look forward to testing it out in the New Year.
(CID:105458767)
Posted: โ2020-07-02 09:24 AM . Last Modified: โ2023-10-31 10:14 PM
