About DCO web client and cluster upgrade question
  • EcoStruxure IT forum
  • About DCO web client and cluster upgrade question
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 05:34 PM . Last Modified: ‎2024-04-08 12:09 AM
923
Hi Team ,
I have asked by customer as the topic and would be appreciated for your advise ,
  1. Due to 8.1 support web client , will it turn slowly(screen lag) if many concurrent users login to web client?  Is this concern hardware spec ?
  2. If DCO cluster need upgrade to new version , can we do the online upgrade? As I know , installed new version of DCO ,then upload the backup to DCO ,process restore  .  This is available when we have another server or vm space , If we don't have , how to upgrade DCO cluster without downtime ?
Best Regards
(CID:122685197)
  • Data Center Operation
Replies 7
924
Hi Chu Li,
I think basically sever performance can depend on it's hardware specs and the running jobs/tasks - for the recommended system specifications, please see the following page : System requirements
Both stand-alone and cluster version should support a direct upgrade (from 8.x to currently 8.1), but in some cases if needed a clean installation followed by restoring the latest backup file could be used as a work-around. However, during an upgrade process (both for stand-alone and cluster) system would be unavailable (so there would be a downtime period), so it would be a good practice to inform the users before planning/starting the product upgrade.
Kind regards
(CID:122685213)
Hi Jef ,
Thanks for your advice ,
Due to our customer is co-lo provider , they will let their customer used DCO tenant portal,
In the future , if DCO new version available and upgrade is need , it's still have downtime for our DCIM system ,am I right ?
Thanks.
Best Regards
(CID:122685390)
Posted: ‎2020-07-03 05:35 PM . Last Modified: ‎2024-04-08 12:09 AM
Hi Chu Li,
You are welcome - that's correct, in general during an upgrade process (from one version to next version) DCO would be unavailable, so you can call this as a downtime period (about 1hr or so). thanks.
Kind regards
(CID:122685427)
Hi Jef ,
Ok , Got it , can you share me the procedure about directly upgrade on cluster environment? Many thanks.
Best Regards
(CID:122685908)
Hi Chu Li,
Upgrade instructions are available here: Getting from previous versions to DCO 8.x
Look for the section saying "Upgrading using the latest 8.x iso file",
"If you are upgrading a cluster environment, you only need to perform the upgrade on the slave node, not the master node. The upgrade takes up to about 20 minutes. You should not try to access or use StruxureWare Data Center Operation during the upgrade."
Kind regards
(CID:122685955)
Hi Jef ,
Thank you for this sharing , it's very useful for me : )
Best Regards
(CID:122685981)
Posted: ‎2020-07-03 05:35 PM . Last Modified: ‎2023-10-20 04:58 AM
