Posted: 2020-07-02 03:28 PM . Last Modified: 2024-04-09 03:09 AM
Hi
I have connected up the above sensor to my Netbotz 200 Device using the ALink connection. When I load the device status page I can see the sensor connected to it.
I am trying to add this device in to StruxureWare DCE so that I can add it in to DCO to monitor our battery room.
Does anyone have any idea how to add this device in to DCE and DCO.
(CID:102924588)
Posted: 2020-07-02 03:29 PM . Last Modified: 2024-04-09 03:09 AM
You have to adjust the Dip switches so they are all in the down position if this is the only sensor, and put the terminator in the other alink port:
http://www.apcmedia.com/salestools/ASTE-6Z5QC9/ASTE-6Z5QC9_R0_EN.pdf?sdirect=true
Once you can see the sensor, you have to discover the device it is connected to and the sensor will show up under the main device in DCE, you can then associate the sensor in DCO if you have DCE added in external systems in DCO
(CID:102924592)
Hi Martin,
The NetBotz 200 is based upon the NMC architecture rather than the NetBotz 3xx, 4xx, and 5xx appliances. The latter are added to DCE using the option to add a NetBotz appliance. To add a NetBotz 200, you'll want to add this device as an SNMP device as per k-base FA225604. Once added to DCE, DCO should also see the readings.
Steve
(CID:102924595)
Posted: 2020-07-02 03:29 PM . Last Modified: 2023-10-31 10:16 PM
