Posted: 2020-07-02 09:49 PM . Last Modified: 2024-04-09 01:39 AM
we have the above APC PDUs installed in our 2 data centers.
I am wondering if the FTP settings on these PDUs need to be enabled for StruxureWare DCE to be able to apply updates to these devices.
thanks
Martin
(CID:105459374)
Dear Martin,
Yes, FTP port needs to be enabled for the device. Please make sure that the following ports are open.
Protocol |
Transfer Protocol |
Ports |
Network |
Comments |
HTTP |
TCP (SSL) |
80 (443) |
Network speed of minimum 100 Mbps is recommended. Bandwidth usage between client and server heavily depends on number of discovered devices, alarm configuration and operations carried out in the client e.g. report generation. |
Communication from NetBotz Appliances / DCE Console/Web API and 3rd party integrations. |
SNMP |
UDP |
161 |
The bandwidth needed heavily depends on number of discovered devices, polling interval configured and alarm activity in the system. |
SNMP Communication between discovered devices and DCE |
SNMP (Trap) |
TCP/UDP |
162 |
Specified in device SNMP configuration |
SMTP |
TCP |
25 |
Network requirements are low. Email traffic from the DCE is depended on alarm policy configuration and number of alarms occurring. |
Communication with e-mail server |
FTP |
TCP |
21 |
Used when device is discovered and DDF file transferred. The network requirements are low. |
Transfer DDF files between devices and DCE |
SCP |
TCP |
22 |
DNS |
TCP/UDP |
53 |
Very limited traffic and bandwidth requirement |
DNS server communication |
For more info: http://dcimsupport.apc.com/display/UADCE725/StruxureWare+Data+Center+Expert+Security |
You can also refer the below K-base: http://www2.schneider-electric.com/sites/corporate/en/support/faq/faq_main.page?page=content&country...
(CID:105459376)
Dear Martin,
Protocol |
Transfer Protocol |
Ports |
Network |
Comments |
HTTP |
TCP (SSL) |
80 (443) |
SNMP |
UDP |
161 |
SNMP (Trap) |
TCP/UDP |
162 |
SMTP |
TCP |
25 |
FTP |
TCP |
21 |
SCP |
TCP |
22 |
DNS |
TCP/UDP |
53 |
(CID:105459376)
Just to add to Bala's comments on FTP specifically, FTP (or scp if enabled) is also needed for firmware updates of the device from DCE.
(CID:105459399)
Posted: 2020-07-02 09:49 PM . Last Modified: 2023-10-31 10:15 PM
