ACF002
  • ACF002
129
72
Posted: ‎2020-07-04 02:45 PM . Last Modified: ‎2024-04-05 02:32 AM
635
ACF002
A colleague of mine inquired about how he would go about modeling the ACF002 Rack Air Distribution Unit. If we encounter this unit in the field would a work around be to just place a tile under the rack with the airflow rating of the device? Will the software accept floor tiles pushing air under a rack and into the cabinet or would the tiles need to be placed in front of the cabinet?
A link to the product is below:
https://www.schneider-electric.us/en/product/ACF002_APC/rack-air-distribution-unit-2u-208-230v-50-60...
Thank you in advance for any assistance.
(CID:129402517)
  • Data Center Operation
Hi Brian,
As you know, when it comes to cooling simulation (in DCO) modeling simple racks (without cooling devices/rack air distribution units) are supported. As you've mentioned using perforated floor tiles might improve the cooling simulation (and should not be placed under a rack) and probably may not represent the real setup. I think if the cooling/temperature simulation should be very important to you/customer, then I would suggest using some temperature sensors and running the 3D temperature map on "Measured plane". That may give you a more realistic temperature plan of the data center.
Kind regards
(CID:129402877)
Posted: ‎2020-07-04 02:45 PM . Last Modified: ‎2023-10-20 04:54 AM
