Posted: 2020-07-06 12:10 AM . Last Modified: 2024-04-02 11:40 PM
Hi All
I m keep getting the error A-Link Bus power - value alert - overloaded, this error coming every 3 mints and goes normal and again coming, can you any one help me on this what exactly causing this and how to fix. I'm having netbotz rack monitor 570 (netbotz91190F) DCE device.
Thanks in advance.
Ramu
(CID:152570065)
Hi Ramu!
This error indicates that A-Link bus is overloaded. May be you have many sensor pods connected to Netbotz. If so, you need to add external power supply in the middle of the chain.
If there are no external devices connected to A-Link port, it indicates that your Netbotz is broken.
(CID:152570086)
Hi Valentin
Thanks for your reply...
this is an existing running environment, this error/issue started just 2 days before and there is no sensors added to the netbotz (recently or before the issue raises), kindly help.
Ramu
(CID:152570095)
Is there any sensor pods attached to the Netbotz at all? If so can you kindly remove?
If not and your device is under warranty can you contact local support as there maybe be a hardware problem.
(CID:152570480)
Posted: 2020-07-06 12:11 AM . Last Modified: 2023-10-20 04:54 AM
