50mm resolution support for EcoStruxure IT Advisor CFD
Send InviteCancel
Posted: 2022-09-2706:59 AM. Last Modified: 2025-04-0211:40 PM
For our paying customers, EcoStruxure IT Advisor CFD now supports equipment and room resolution in 50mm (2 inch) increments.
This allows, for instance, an often requested ability to model 800mm racks.
Placing and moving equipment in a data center continues to be a smooth and easy process. Equipment will continue to snap to the preferred placement grid (150mm intervals), but also, will snap to other equipment edges. When you don't want to use the mouse to drag equipment around, EcoStruxure IT Advisor CFD has a 'Move' menu. Use the menu or keyboard shortcuts to move equipment in either 50mm or 150mm amounts.
If you want to dig in deeper, you can use the new CFD Grid button to see the underlying grid that will be used when doing the CFD calculations.
Modeling your data center in 150mm (6 inches) continues to be the recommended 'sweet spot' for data center CFD. However, for the times that you need just a bit more, EcoStruxure IT Advisor CFD supports 50mm resolution.
