Posted: 2020-07-02 05:45 PM . Last Modified: 2024-04-09 02:12 AM
I am taking error when I reviewing 3d temparature map.
The error is; There was an error computing or displaying the temparature map. Consult the log for details.
Could you help me abaout this issue.
Best Regards,
Barlas.
(CID:104175052)
Posted: 2020-07-02 05:46 PM . Last Modified: 2024-04-09 02:12 AM
Thanks I solved the issue. I moved all cabinets to new room. So I solved that way.
Best Regards,
Barlas.
(CID:105468368)
Hello Barlas, Can you please share the log files that are located in the directory below so we may analysis the error. C:\Users\
(CID:104175056)
Hello Victor, You may find log data below
(CID:104175097)
Hi Barlas (& Victor), I was wondering how it goes with this case? I can take a look if the issue is not resolved yet, then I would need the following data: 1) the client "application.log" file, (C: \Users\
(CID:104175336)
Dear Jeff, thanks for your reply. My issue is not resolved yet. I uploaded all log files to your box. Best Regards, Barlas.
(CID:104175380)
Hi Barlas,
Many thanks for providing the data. It seems basically it is a network related issue, the client logs contain error messages complaining about the connection to the server:
Error (Connection lost, response code:null) ExternalWebServiceService.getExternalEvents() @ http://xxx.xxx.xxx.xxx:80/isxo/core/external/ExternalWebService
SocketTimeoutException invoking http:/xxx.xxx.xxx.xxx::80/isxo/core/external/ExternalWebService: connect timed out
(replaced the server IP with xxx.xxx.xxx.xxx)
It seems you have been trying to run the temperature calculations after losing the connection to server. As illustrated the red led (from your shared data) is also an indication of the lost/bad connection to the server (should be green for a good connection):
Hope this helps,
Kind regards
(CID:104181376)
Best Regards,
Barlas.
(CID:105468368)
Hi Barlas, Great! many thanks for taking the time and sharing how you've resolved it, thanks Kind regards
(CID:105468369)
Posted: 2020-07-02 05:46 PM . Last Modified: 2023-10-31 10:12 PM
