Posted: 2020-07-02 04:37 PM . Last Modified: 2024-04-09 02:44 AM
Hi Team,
Could you provide the specification how the each billboard information are calculated from DCE or ITO temperature data?
If possible, can you explain based on the case which DCE-DCO and ITO-DCO communication interval are 5 min.
best regards,
Yoshi
(CID:103585703)
Posted: 2020-07-02 04:38 PM . Last Modified: 2024-04-09 02:44 AM
Hi Yoshinobu Suzuki - thank you for posting. I'll see who can be of assistance here. Meanwhile @community - any ideas?
(CID:103586049)
Hi Yoshi-san,
I will try to find more info (for our documentation), but in the mean time could you please watch the following video tutorial and see if that helps:
How to setup live temperature mapping in StruxureWare Data Center Operation
Kind regards
(CID:103586101)
Hi Yoshi,
DCO retrieves the actual temperature measurements reported by the external system, very close to real-time with a max delay of 5 mins per default (external system setting).
How these max and average values are calculated is outside the scope of DCO as this is defined by the external system.
Hope this clarifies what is handled on the various systems.
For further information about the temperatures displayed in 3D, see Working with the 3D Temperature Map or watch the video referenced by Jef.
Best regards, Pernille
(CID:103586190)
Posted: 2020-07-02 04:38 PM . Last Modified: 2023-10-31 10:46 PM
