DCE Firmware update
  • DCE Firmware update
129
112
72
Posted: ‎2020-07-02 08:45 AM . Last Modified: ‎2024-04-10 01:24 AM
699
DCE Firmware update
What is the configuration setup for DCE trying to download firmware from updates.apc.com. What ports need to be enabled for this functionality to work?
(CID:90898968)
Hi Hiren,
For your reference, all the ports that Central needs to operate are listed on KBase FA158328. The link below is to access this KBase:
http://www.apc.com/site/support/index.cfm/faq/
You need to allow traffic to updates.apc.com.
Updates.apc.com uses port HTTPS.
If you are having problems contacting the APC Update server. I would check the proxy/firewall settings (make specific exceptions in their firewall for updates.apc.com).  There is also the possibility of running a packet capture on the network to see what is happening.
There is also another option if you are unavailable to access the Internet for the updates. There is a firmware catalog file that can be uploaded locally to the server itself. The link to this firmware catalog is below (SKU number SFISXCFC50): (The latest catalog was uploaded on the 17th September)
http://www.apc.com/tools/download/software_comp.cfm?sw_sku=SFISXCFC50&id=350&family=&part_num=&swfam...
B
(CID:90898981)
Posted: ‎2020-07-02 08:45 AM . Last Modified: ‎2023-10-31 10:27 PM
