Tooltip text Animation not working
Showing results forย
Did you mean:ย
Select a Country
  • Remote Operations
  • Tooltip text Animation not working
sbeadle
sbeadle Champion
335
AndrewScott
AndrewScott
125
BevanWeiss
BevanWeiss
103
  • Remote Operations Forum
EcoStruxureโ„ข Geo SCADA Expert
HOSS
HOSS Contributor
Contributor
Posted: โ€Ž2021-05-26 06:19 AM . Last Modified: โ€Ž2023-05-03 12:03 AM
1647
I'm trying to make a dynamic tooltip text, as I want to make a certain object (for example a pump) tell me it's status when I hover over it.
The problem it I'm still having the text show up as a text not a running expression.
the expression is (".Testing.Reservoir.Running.CurrentStateDesc")
Hossam Embaby
  • Scripting
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
HOSS
HOSS Contributor
Contributor
Posted: โ€Ž2021-05-26 06:55 AM
Well ... ๐Ÿ˜„
the solution is to write the expression in Tooltip text option in the animation tab not in the properties tab.
i guess it's quite easy ๐Ÿ˜„ i don't know why it took me so long to make it
Hossam Embaby
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
HOSS
HOSS Contributor
Contributor
Well ... ๐Ÿ˜„
Hossam Embaby
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2026 Schneider Electric
