Posted: 2020-03-03 10:57 AM . Last Modified: 2023-05-03 12:16 AM
[Using ClearSCADA 2017 R3]
I have a structured text program that is calculating a date and time from 2 FloBoss integers. INT1 is the Date (without year) and is a 4-digit value (e.g. 0226). INT2 is the 4-digit Time in 24h format (e.g. 1442). I've successfully gotten to the point in my ST program where I have the date. Unfortunately for dates that straddle the year for this device, I need to be able to subtract 1 year from the date. I use the current date and time to extract 'YEAR' and do a couple of concatenations to get the time:
dtDate := MAKE_DATE(YEAR, STRING_TO_SINT(strMonth), STRING_TO_SINT(strDay));
dtTime := MAKE_TIME_OF_DAY(STRING_TO_SINT(strHour), STRING_TO_SINT(strMins), 0, 0);
DATETIME := CONCAT_D_TOD(dtDate, dtTime);
But the final function that compares the current time to the calculated time is giving me the error 'Program Error: Invalid conversion'
IF DATETIME > dtCurrentTime THEN
DATETIME := SUB_DT_TIME(DATETIME, STRING_TO_TIME('D#1y'));
END_IF;
The program compiles just fine, I only get the error when I execute the program.
Posted: 2020-03-03 11:23 PM
Might have been able to get away with:
DATETIME := SUB_DT_TIME(DATETIME, T#365d);
Although would need to take leap years into account.
Posted: 2020-03-03 12:08 PM . Last Modified: 2020-03-03 12:09 PM
If these are all INTs... why are you doing anything with STRINGs?
CURR_INT1 := EXTRACT_DT_MONTH(NOW()) * 100 + EXTRACT_DT_DAY(NOW());
CURR_INT2 := EXTRACT_DT_HOUR(NOW()) *100 + EXTRACT_DT_MINUTE(NOW());
IF( CURR_INT1 > INT1 OR (CURR_INT1 = INT1 AND CURR_INT2 >= INT2)) THEN
(* Our datetime event was this year.. *)
(* We don't care about Seconds / Milliseconds, so set these to zero *)
(* INT1 = MMDD, INT2 = HHMM *)
DATETIME := MAKE_DATE_AND_TIME( YEAR, DIV( INT1, 100), MOD(INT1,100), DIV(INT2,100), MOD(INT2,100), 0, 0 );
ELSE
(* our datetime event was last year *)
DATETIME := MAKE_DATE_AND_TIME( YEAR - 1, DIV( INT1, 100), MOD(INT1,100), DIV(INT2,100), MOD(INT2,100), 0, 0 );
END_IF;
Posted: 2020-03-03 12:57 PM
That did the trick! Thanks so much. I though I'd have to convert to strings to parse off the month/day and hour/min.
Posted: 2020-03-03 11:37 PM
@Anonymous user How did you get somewhat good syntax colouring on your ST Logic text? Did you have to colour it yourself?
@AdamWoodland It is a little frustrating that the logic engine (and many parts of ClearSCADA) can't do subtraction of things like months / years etc (conceptual time periods). I was a bit afraid that 1year in days would overflow the holding of the 'Time' datatype. What is the extent of what it can hold?
Posted: 2020-03-04 02:21 AM
That was 'C' language colouring. Colours function names red but is unaware of (* *) comments.
Time and its text representations support, for example, a century's worth of seconds in Adam's example.
