Sorting Problem
  • Remote Operations
  • Sorting Problem
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
abdullah123456789
Lt. Commander abdullah123456789
Lt. Commander
Posted: ‎2022-09-09 02:23 AM . Last Modified: ‎2023-05-02 11:52 PM
2093
Sorting Problem
I displayed the 'Historic List' in Geo SCADA Expert 2021. But, when i listed the datas with sorting by value, sorting is step by step, not the whole number as in the screenshot. I need to sort the datas 'descend' like 9898-9821-9730-9723-987-98. Where can i find this sorting settings?
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
Replies 6
Experimentalist
Lieutenant JG Experimentalist
Lieutenant JG
Posted: ‎2022-09-09 02:31 AM
3
2085
Hi
It looks like your query is using formatted value which is a string. Include the value column which is a number and sort by that. Use the schema to find the column you need
Regards
Ex
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2022-09-09 03:10 AM
In response to Experimentalist
2
2080
You may wish to display the text column (with units) but sort by the numeric value.
Sorted columns must appear in the SELECT column list, so add an underscore to the name alias to hide a column.
e.g:
SELECT TOP( 1000000 )
"RecordId", "RecordTime" AS "~Time", "FormattedValue", "ValueAsReal" AS "_ValueAsReal", "StateDesc", "QualityDesc", "ReasonDesc", "StatusDesc", "SuppressionTypeDesc", "Foreground", "Background", "Blink", "FileOffset" AS "_FileOffset"
FROM
CDBHISTORIC
WHERE
"Id" = 423621 AND "~Time" BETWEEN { OPC 'Hour - 23 Hours' } AND { OPC 'Hour - 23 Hours+1 Day' }
ORDER BY
"_ValueAsReal" ASC
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
MF_SHAIKH
Ensign MF_SHAIKH Ensign
Ensign
Posted: ‎2022-09-09 08:08 AM
2062
You can try below query
select * from table_name order by abs(column_name) desc;
Hope it helps..
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-09-11 05:49 AM
In response to MF_SHAIKH
Why would you include the Absolute function (abs)??
SELECT column_name
FROM table_name
ORDER BY column_name DESC
Would do the ordering.
Including ABS(xx) is superfluous and significantly hurts performance.
It requires an additional mathematical calculation (to take the absolute of the column value), and reduces the ability of the query processor from being able to use some additional ordering optimisations.
As Steve mentioned however, this would result in the column no longer having nice unit formatting (i.e. m/s etc) since to add the unit requires the column be a string type, which then results in lexigraphic sorting (i.e. by character value, not numeric value).
Having a hidden column of the desired sort is the best work around.  However if the sorting needs to be dynamic (i.e. controlled by a user) then this isn't as usable.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
abdullah123456789
Lt. Commander
Posted: ‎2023-01-29 10:32 PM
In response to sbeadle
1700
Thank you for your help but it didn't solve my problem literally. Because it adds a new column and sort datas according to this column and hide the column. The problem starts here, when i change the sort column i am not sorting according to this column again because it is hidden.
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2023-01-30 01:35 AM
In response to abdullah123456789
So I guess if you want users to choose which column to sort, then you'll need to use the numeric value without units:
"RecordId", "RecordTime" AS "~Time",  "ValueAsReal", "StateDesc", "QualityDesc", "ReasonDesc", "StatusDesc", "SuppressionTypeDesc", "Foreground", "Background", "Blink", "FileOffset" AS "_FileOffset"
FROM
CDBHISTORIC
WHERE
ORDER BY
"ValueAsReal" ASC
If you need units on display then you could bring that in from the point table using a join.
