Script for Acknowledge All Alarms
  • Remote Operations
  • Script for Acknowledge All Alarms
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Posted: ‎2020-12-27 09:27 AM . Last Modified: ‎2023-05-03 12:06 AM
3477
Hello Experts,
Newbie to Clear SCADA.
I have made a dedicated mimic for alarms lists.
How can I acknowledge the alarms (All Alarms) based on a button press?
Tried searching the help in Clear SCADA but not succeeded in finding a script to Acknowledge all alarms.
Only way is to click the alarm lists and individually Acknowledge. Pressing  key "A" acknowledges  the selected alarm aswell.
I have seen other discussions about ALARM banner multiple acknowledgment. But my requirement is using a script or some other way to acknowledge all alarms in an alarm list.
Kindly help.
  • Scripting
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2020-12-27 08:19 PM
2
3443
Script is definitely not the easiest way to do this.
Easiest is:
  1. Create button (or object to have pick action)
  2. Select Pick Action Wizard... from right click context menu
  3. Select Method (and Next >)
  4. Select Object = $Root (I'd recommend making it not relative)
  5. Set Method = 'Acknowledge Alarms'
  6. 'Next >', 'Next >',  then 'Finish'
  7. Done
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
2
3444
Easiest is:
  7. Done
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Posted: ‎2020-12-27 08:50 PM
In response to BevanWeiss
3438
Wow, Thanks for the detailed reply.
It worked simply.
Seems I need to explore options in ClearScada in detail again.
For printing the alarm lists on a button action is there any specific referencing for the script? Right clicking the alarmlist gives an option to print. but customer is requesting a button for that.
Currently I am using below script. But it prints the entire mimic.
sub Print()
Mimic.Print
end sub
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2020-12-27 10:03 PM
In response to Anonymous user
New topics / questions should have new topics 😉
As always, the best guidance is to have a look at the Database schema.  Reference can be found to this in the help documentation.
A shortcut for the default installation would be to just navigate to
https://locahost/schema
Then you can browse through all the properties / methods available on the various object types in the database.
Once you've found a property / method that represents what you're after then getting access to it is almost always possible using either the built in ViewX objects (like the pick action mentioned before) or using Logic (server side operation) / Scripting (client side operation).
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
