SQL Export limited to 100000 rows
  • Remote Operations
  • SQL Export limited to 100000 rows
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Saminpa
Saminpa
Cadet
Posted: ‎2022-06-15 10:34 AM . Last Modified: ‎2023-05-02 11:55 PM
2
4162
Hi All,
I am relatively new to GeoSCADA so maybe I am missing something but I am having some difficulty extracting a fairly large amount of data for offline analysis of a control problem.
What I had set up was a SQL Export to a csv file (below) but there were a number of issues with extracting the 10 points I needed.
1. I could not figure out how to [without creating a horrendous join] get the data to come out as timestamp + 10 columns instead of one concatenated column, hence the single-point query in the photo
2. I resigned myself to having to do 10 exports and align the data by hand but then realized that no matter what I did my csv file was truncated at 100000 rows even though (second photo below) Server Configuration\SQL Query Configuration\Parameters\Query Row & Size Limit are set at 5000000 and 250 MB
3. That meant that I had to do 50 individual exports to get all the data I needed and I'm still working on aligning all of it manually which is just a little bit insane, there has to be an easier way
Can someone please tell me what I am doing wrong?
Thanks!
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2022-06-23 04:53 AM . Last Modified: ‎2022-06-23 05:39 AM
The "HKEY_LOCAL_MACHINE\SOFTWARE\Schneider Electric\ClearSCADA\DriverSQLExport\MaxRows" registry setting defines the maximum number of rows returned by the queries in SQL export driver (default 100,000).
The driver will need to be restarted after changing this setting for it to take effect.
Care needs to taken when increasing this as it can adversely effect system performance if set too high.
Andrew Scott, R&D Principal Technologist, AVEVA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
AndrewScott
Admiral AndrewScott
Admiral
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Samueljonas
Crewman Samueljonas
Crewman
Posted: ‎2022-06-29 12:51 AM . Last Modified: ‎2022-06-29 09:21 PM
@Saminpa wrote: MonkeyCool
Hi All,
Thanks!
Do you know exact number of rows to be exported? Did you check it..
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
