SOAP XML - Method Override CDBPoint
  • Remote Operations
  • SOAP XML - Method Override CDBPoint
sbeadle
Kirk sbeadle Kirk
319
AndrewScott
Admiral AndrewScott
114
BevanWeiss
Spock BevanWeiss
97
EcoStruxure™ Geo SCADA Expert
Posted: ‎2021-11-02 07:17 AM . Last Modified: ‎2023-05-03 12:00 AM
2213
I am testing the XML SOAP of Geo SCADA Expert. The software used is SOAPUI 5.6.
I would like to execute "Override" method through SOAP.
I am able to execute this method without argument (here below the syntax of the SOAP xml query).
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:scx6="http://serck-controls.com/webservices/SCX6/">
   <soapenv:Header/>
   <soapenv:Body>
      <scx6:ExecuteMethod>
         <scx6:Object>_TESTS.PointAnalogTest</scx6:Object>
         <scx6:Method>Override</scx6:Method>
         <!--Optional:-->
         <scx6:Arguments>
            <!--1 or more repetitions:-->
            <scx6:Argument></scx6:Argument>
         </scx6:Arguments>
      </scx6:ExecuteMethod>
   </soapenv:Body>
</soapenv:Envelope>
The reply is OK.
However, when I set an argument such as 2 (here below), error occurs.
   <soapenv:Header/>
   <soapenv:Body>
         <!--Optional:-->
         <scx6:Arguments>
            <scx6:Argument>2</scx6:Argument>
         </scx6:Arguments>
   </soapenv:Body>
</soapenv:Envelope>
Does somebody have any idea how to send argument through the method in SOAP ? which syntax is needed ?
Thank by advance,
  • SCADA
  • Telemetry
  • WebX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2021-11-03 06:12 AM
In response to Anonymous user
2182
Sorry, I forgot to mention that you also need to define the xsi namespace for the xsi:type attribute:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:scx6="http://serck-controls.com/webservices/SCX6/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
   <soapenv:Header/>
   <soapenv:Body>
         <!--Optional:-->
         <scx6:Arguments>
            <scx6:Argument xsi:type="xsd:double">12</scx6:Argument>
         </scx6:Arguments>
   </soapenv:Body>
</soapenv:Envelope>
Andrew Scott, R&D Principal Technologist, AVEVA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Replies 4
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2021-11-03 02:50 AM
2194
The <scx6:Argument> element is missing the xsi:type attribute to define what kind of value the argument is.
For example, for an analogue point override using double precision floating point value:
<scx6:Argument xsi:type="xsd:double">12.34</scx6:Argument>
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Posted: ‎2021-11-03 04:07 AM
In response to AndrewScott
2191
Justed checked.
The reply of the scada is unfortunately NOK: "the request body was not valid" whatever the xsd type (like int, float, double, short, long, etc.). Here below the print screen.
It becomes better when "xsi" and the value are removed...
It seem working properly, however no value is sent...
Any idea ? Are you sure of the syntax ? Is there no error message from the soap server when the type is wrong ?
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AndrewScott
Admiral AndrewScott
Admiral
2183
   <soapenv:Header/>
   <soapenv:Body>
         <!--Optional:-->
         <scx6:Arguments>
         </scx6:Arguments>
   </soapenv:Body>
</soapenv:Envelope>
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Posted: ‎2021-11-03 06:28 AM
It is working now.
Good job. Thank you so much.
Cheers,
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
