SCADA Expert randomly change language
  • Remote Operations
  • SCADA Expert randomly change language
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Machine SCADA Expert
EcoStruxure™ Geo SCADA Expert
FabioMolinaris
Ensign FabioMolinaris
Ensign
Posted: ‎2022-03-25 02:31 AM . Last Modified: ‎2023-05-02 11:57 PM
2591
Hi community,
I'm using a Grid object in SCADA Expert for visualize an SQL table with a date and time variable. The problem is that i set the Windows language in italian and the date use the correct locale date format dd/mm/yyyy but sometimes (appear to be random) it use the US date format mm/dd/yyyy
Is there some weird place to set the language of the project or of the runtime?
Someone have already had this problem?
F
  • IoT
  • SCADA
  • grid
  • language
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
Replies 5
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2022-03-25 02:59 AM
2589
The language and date-time format for a Geo SCADA user is set in the user's regional settings, see https://tprojects.schneider-electric.com/GeoSCADAHelp/Geo%20SCADA%202020/Default.htm#SecurityGuide/D...
For the guest user, see https://tprojects.schneider-electric.com/GeoSCADAHelp/Geo%20SCADA%202020/Default.htm#SecurityGuide/D...
The guest user also has settings in ViewX, see https://tprojects.schneider-electric.com/GeoSCADAHelp/Geo%20SCADA%202020/Default.htm#ClientAdministr...
Andrew Scott, R&D Principal Technologist, AVEVA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
FabioMolinaris
Ensign
Posted: ‎2022-03-25 03:21 AM
In response to AndrewScott
2581
Actually I'm on SCADA Expert and not Geo SCADA (sorry if that wasn't clear or if I've misplaced my post) and I'm not able to find all this settings.
The only thing that I've found is a SetDateFormat function but, again, sometimes doesn't work
F
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2022-03-25 03:46 AM . Last Modified: ‎2022-10-19 01:00 AM
In response to FabioMolinaris
2577
@FabioMolinaris I've not heard of a product called "SCADA Expert", this forum is for the "Geo SCADA" product, which was previously called "ClearSCADA" prior to 2019.
https://community.se.com/t5/Geo-SCADA-Knowledge-Base/Geo-SCADA-Expert-Releases/ba-p/279082
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
FabioMolinaris
Ensign
Posted: ‎2022-03-25 03:50 AM
The product is this one https://www.se.com/ww/en/product-range/63734-ecostruxure-machine-scada-expert/
Thanks for the effort
F
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
MF_SHAIKH
Ensign MF_SHAIKH Ensign
Ensign
Posted: ‎2022-08-30 01:13 AM
You can Put SetDateFormat in the statup or the page which open always like Header.
Hope it helps
Faisal
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
