Read a DataTable Modify it and Save into a new Table from GeoScada VBscript
  • Remote Operations
  • Read a DataTable Modify it and Save into a new Table from GeoScada VBscript
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Posted: ‎2022-06-21 08:41 AM . Last Modified: ‎2023-05-02 11:55 PM
1587
Hi Experts,
I need some help with Modifying an existing data table.
What I need help with is creating a visual basic script to read in the confifuration of an existing data table, do a string replace on specific cell configuration and then write the information into a new data table.
For example my Data is
'GASWELL'FORMATVAL('yyyyMMdd',"Canbriam.~Config.Logic.ProductionDate")Canbriam.SCADA.b-72-A Field.c-07-H_94-B-8.Well 1.Gas Meter.Meter Parameters.Meter IDFORMATVAL('0.00',"Canbriam.SCADA.b-72-A Field.c-07-H_94-B-8.Well 1.Gas Meter.Daily Values.PDay Hrs Ydy.CurrentValue")    FORMATVAL('0.00',"Canbriam.SCADA.b-72-A Field.c-07-H_94-B-8.Well 1.Wellhead.Casing;Average;D-16H;1D")FORMATVAL('0.00',"Canbriam.SCADA.b-72-A Field.c-07-H_94-B-8.Well 1.Wellhead.Tubing;Average;D-16H;1D")    FORMATVAL('0.00',"Canbriam.SCADA.b-72-A Field.c-07-H_94-B-8.Well 1.Sand Separator.Sand Pressure;Average;D-16H;1D")  FORMATVAL('0.00',"Canbriam.SCADA.b-72-A Field.c-07-H_94-B-8.Well 1.Gas Meter.Daily Values.PDay Temp.CurrentValue")FORMATVAL('0.00',"Canbriam.SCADA.b-72-A Field.c-07-H_94-B-8.Well 1.Gas Meter.Daily Values.PDay Static Press.CurrentValue")FORMATVAL('0.00',"Canbriam.SCADA.b-72-A Field.c-07-H_94-B-8.Well 1.Gas Meter.Daily Values.PDay Diff Press.CurrentValue")
Which I need to Change to
'GASWELL''20220614'"Canbriam.SCADA.b-72-A Field.c-07-H_94-B-8.Well 1.Gas Meter.Meter Parameters.Meter ID"FORMATVAL('0.00',"Canbriam.SCADA.b-72-A Field.c-07-H_94-B-8.Well 1.Gas Meter.Daily Values.PDay Hrs Ydy;Start;D+7H59M59S-5D;1H")    FORMATVAL('0.00',"Canbriam.SCADA.b-72-A Field.c-07-H_94-B-8.Well 1.Wellhead.Casing;Average;D-5D16H;1D")FORMATVAL('0.00',"Canbriam.SCADA.b-72-A Field.c-07-H_94-B-8.Well 1.Wellhead.Tubing;Average;D-5D16H;1D")    FORMATVAL('0.00',"Canbriam.SCADA.b-72-A Field.c-07-H_94-B-8.Well 1.Sand Separator.Sand Pressure;Average;D-5D16H;1D")  FORMATVAL('0.00',"Canbriam.SCADA.b-72-A Field.c-07-H_94-B-8.Well 1.Gas Meter.Daily Values.PDay Temp;Start;D+7H59M59S-5D;1H")FORMATVAL('0.00',"Canbriam.SCADA.b-72-A Field.c-07-H_94-B-8.Well 1.Gas Meter.Daily Values.PDay Static Press;Start;D+7H59M59S-5D;1H")FORMATVAL('0.00',"Canbriam.SCADA.b-72-A Field.c-07-H_94-B-8.Well 1.Gas Meter.Daily Values.PDay Diff Press;Start;D+7H59M59S-5D;1H")
My D- Offset will change depending on a variable I enter elsewhere.
I can't seem to figure out how to read in the CDataTable Object into VBA where I can modifiy it.
  • Scripting
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
Posted: ‎2022-06-23 08:35 PM
In response to Anonymous user
For Anyone that may come across this in the future the commands are
DataSet.Interface.GetCellExpr(r,c)
DataSet.Interface.SetCellExpr r,c,string
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2022-06-21 09:59 AM
1573
Are you sure you're using a data table and not a data grid?
The example shown above shows cells containing expressions, but data tables store values (numbers, strings, dates etc.) not expressions in each cell.
Both tables (CDataTable and CDataGrid) have database methods that can modify them, see the database schema for details of the available methods. For data grids the GetCellExpr() and SetCellExpr() methods can be used to get/set the expression in an individual cell of the grid.
Andrew Scott, R&D Principal Technologist, AVEVA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Posted: ‎2022-06-21 02:03 PM
In response to AndrewScott
1560
You are correct. It is a DataGrid, not a table. Sorry for my error.
If the DataGrids are labelled
DataGrid1
DataGrid2
Could you provide an example on a VBscript to:
Load DataGrid1
Read 0,0 from DataGrid1 into Array of string
Load DataGrid2
Write 0,0 from ArrayofString to DataGrid2
I'm unsure of the syntax
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
