Re-Evaluate Redirection Alarms from Logic (or other redirection)
Select a Country
  • Remote Operations
  • Re-Evaluate Redirection Alarms from Logic (or other redirection)
sbeadle
sbeadle Champion
335
AndrewScott
AndrewScott
125
BevanWeiss
BevanWeiss
104
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
MichaelAur
MichaelAur
Contributor
Posted: ‎2025-05-12 01:08 AM
1424
Hello all,
Is there some way to trigger a re-evaluation of alarm escalation on one point based on the change of state on another point?
The reason I am trying to do this is that we have some points that are related in the field and we want escalations based on if the field states changed correctly. For example, we have Mains Failed and Genset Running points set up as below.
  • Mains Failure:
    • Triggers a low-level alarm by default
    • Has escalation 1 set to critical after 10min and enabled (trigger type 3)
    • Has escalation 2 & 3 set to high after 4 then critical 8 hours and enabled (trigger type 3)
  • Generator Running:
    • Triggers low-level alarm by default
    • Has escalation 1&2 set to high after 4 then critical after 8 hours and enabled (trigger type 3)
    • Has escalation 3 set to high after 30min and disabled (trigger type 0)
We disable escalation 1 of Mains Failure when the generator is running (as things have worked as meant and the generator turned on automatically) but problem comes when we try enable escalation 3 of generator running when mains is restored (as we want to know if the generator has stayed on after it should have turned off). While we can cause this escalation to be enabled it misses its trigger condition and therefore never triggers this earlier alarm escalation. I know you can trigger a re-evaluation on the same point when state changes (using alarm redirection> change priority action), but im unsure how to go about triggering it on one point based on the change of another point.
If anyone knows how to do this or has some advice on an alternative/more effective way to trigger this behaviour i would love to hear.
  • Logic
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
MichaelAur
MichaelAur
Contributor
Posted: ‎2025-05-13 12:56 AM . Last Modified: ‎2025-05-14 09:40 PM
Hey Adam,
Thanks for your reply. Your right there is the RestartRedirection function which I overlooked the first time, thinking it was for only if you had stopped redirection. I found this Knowledge Base useful Restarting Alarm Redirection - Schneider Electric Community.
I ended up creating a script which I execute whenever mains available changes state, and in this I enable/disable the redirection. I made it so that all of the redirections that are enabled/disabled are in the 'Conditional' group allowing me to turn them on and off.
(*Triggered by change of state on Mains Available point
 will enable the redirection on genset running for if both genset and mains are running*)
PROGRAM UpdateRedirectionsOnMainsSupplyChanges
	METHOD
		RestartGensetRunningRedirections AT %M(..Points.Digital Outputs.Genset Running.RestartRedirections):STRING;
		CancelGensetRunningRedirections AT %M(..Points.Digital Outputs.Genset Running.CancelRedirections):STRING;
	END_METHOD
	VAR
		mainsAvailable AT %I(..Points.Digital Outputs.Mains Supply Available): BOOL;
		gensetWithMainsRedirection AT %Q(..Points.Digital Outputs.Genset Running.AlarmRedirection.TriggerType7): SINT;
	END_VAR
	IF mainsAvailable THEN
		(*Whenever mains becomes available enable the redirection and then force all 'conditional' redirections to be re-enabled/reevaluated.*)
		gensetWithMainsRedirection:= 3;
		RestartGensetRunningRedirections('Conditional');
	ELSE
		(*Whenever mains is failed disable the redirection and force all 'conditional' redirections to be cancelled.*)
		gensetWithMainsRedirection:= 0;
		CancelGensetRunningRedirections('Conditional');
	END_IF;
	(*Note: This 'conditional' group for redirection is manually setup an will affect all redirecrtions of this group on a specific object*)
END_PROGRAM
AdamWoodlandToo
AdamWoodlandToo
Mentor
Posted: ‎2025-05-12 08:42 PM . Last Modified: ‎2025-05-12 08:42 PM
There is a RestartRedirections method on CAlarmObject that may do what you want but I haven't use it in a long time to see if there are nuances with it. You could can call this directly or from logic triggered as a redirection action when cleared rather than on change?
The issue will be the mapping of the source to target, i.e. which points need to clear to restart redirections on a target? Hard-coding it is one option but probably not scalable.
If RestartRedirections doesn't work, one less neat option is calling the reprioritise action twice, once -1 and once +1, and restart redirections from that shuffle
MichaelAur
MichaelAur
Contributor
Hey Adam,
	METHOD
	END_METHOD
	VAR
	END_VAR
	ELSE
	END_IF;
END_PROGRAM
