Question iec 104 digital output point
  • Remote Operations
  • Question iec 104 digital output point
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
Johnny07
Ensign Johnny07
Ensign
Posted: ‎2025-08-14 05:53 AM
811
I have an IEC 104 digital output point. When I control this point from GeoSCADA and set it to '1', the point is successfully updated both in GeoSCADA and in the PLC—everything works as expected.
However, if the point is changed to '0' directly in the PLC (for any reason), will the digital output point in GeoSCADA also be updated accordingly, even though it's defined as a digital output point?
  • Drivers
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2025-08-28 02:06 AM
2
754
Hi Johnny,
not sure why this didn't get some kind of answer. Generally, most drivers supporting controls will enable their value to be read from the device, so when you send a 'Control to 1', you get a 'Value is 1' coming back. This does depend on device functionality, which we're not in (erm) control of.
Steve
sbeadle
Kirk sbeadle Kirk
Kirk
2
755
Hi Johnny,
Steve
Johnny07
Ensign Johnny07
Ensign
Posted: ‎2025-09-16 12:01 AM
In response to sbeadle
Hello Steve, thanks for your answer, i will discuss this with our PLC programmer. i think it has something to do with the 104 type used for this point.
Johnny07
Ensign Johnny07
Ensign
Posted: ‎2025-09-25 06:07 AM
in the PLC there where different IOA adresses for writing and reading, the PLC Programmer changed this to the same addresses for write and read, and instantly it worked. Thanks for your support.
