Querying compressed historic values for per minute values
  • Remote Operations
  • Querying compressed historic values for per minute values
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
115
BevanWeiss
Spock BevanWeiss
98
  • Remote Operations Forum
dtappen1
Crewman dtappen1
Crewman
Posted: ‎2025-01-21 10:28 AM
621
We are attempting to get per minute historic results using a SQL query.  The queried point uses historic compression during storage.  Since compression is abled for "significant change", there are minutes that do not have a value in the result set.  How do we get a result set with a value per minute, regardless of whether the there is a stored historic value (i.e. data changed significantly or not)?
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2025-01-23 01:37 AM
You may find it convenient to configure a Historic View - a new virtual SQL table. This can be set to a 1 minute interval, and you can pick the type of summarisation, e.g. End Last. The View will give you a column with a quality number, telling you if that 1 minute sample was derived from adjacent values or one/more vales in each 1 minute window. Search for 'Create a Historic View' in F1 help.
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2025-01-22 01:32 AM
Which algorithm are you using to process the historic data?
An interpolated algorithm will give you values for periods where there is no data.
For example: Average Interpolated
Andrew Scott, R&D Principal Technologist, AVEVA
sbeadle
Kirk sbeadle Kirk
Kirk
