Posted: 2020-06-28 10:27 PM . Last Modified: 2023-05-03 12:13 AM
Hello! I need to replicate some logic in ClearSCADA code in .NET. The scada code selects values from a View and does some processing.
Does anyone know what API calls can query the View and get its data? Thanks a lot.
Posted: 2020-06-29 02:51 AM
What do you mean by a View - a SQL query?
An SQL query can be made on the .Net API using the Advanced connection type.
// Non-working code as an example:
var node = new ClearScada.Client.ServerNode(ClearScada.Client.ConnectionType.Standard, "127.0.0.1", 5481);
AdvConnection = node.Connect("mytest", false); // New type argument
using (var spassword = new System.Security.SecureString())
foreach (var c in password)
spassword.AppendChar(c);
AdvConnection.LogOn(user, spassword);
// Fix indenting!
Int32 result = 0;
String sql = "select id from cgroup"
// Find the database reference of the thing
ClearScada.Client.Advanced.IQuery serverQuery = AdvConnection.PrepareQuery(sql, new ClearScada.Client.Advanced.QueryParseParameters());
ClearScada.Client.Advanced.QueryResult queryResult = serverQuery.ExecuteSync(new ClearScada.Client.Advanced.QueryExecuteParameters());
if (queryResult.Status == ClearScada.Client.Advanced.QueryStatus.Succeeded || queryResult.Status == ClearScada.Client.Advanced.QueryStatus.NoDataFound)
if (queryResult.Rows.Count > 0)
// Found
IEnumerator<ClearScada.Client.Advanced.QueryRow> e = queryResult.Rows.GetEnumerator();
while (e.MoveNext())
result = (Int32)e.Current.Data[0];
serverQuery.Dispose();
// Fix indenting!
Int32 result = 0;
// Found
Posted: 2020-06-29 02:58 AM
Hi sbeadle,
Thanks heaps for answering my question.
I tried your solution and it works! The view in my question refers to the Historic Views defined in Historic Configuration.
Thank you again and have a nice day!
Kan
Posted: 2020-06-29 08:42 PM
Hey Steve,
That's quite some old style enumerator iteration there
You're not a fan of the 'foreach'?
There's really so much more power in the .NET stuff around this, like doing processing in parallel..
Posted: 2025-02-26 07:26 PM . Last Modified: 2025-02-26 07:29 PM
For anyone stumbling upon this in 2025, below is the same code (mostly!) as Steve's for Geo SCADA 2023 and PowerShell 5.1 (removed a load of exception handling to simplify things a little)
